Go Back   Pashnit Motorcycle Forum > General Forums > Mods, Gadgets & Gear
Old 08-15-2012, 06:40 PM   #1
n0cars4me
Kinda new round here
n0cars4me's Avatar
  LA
  zuki
Lets Eat grease ninja review
Hello,
I would like to share this neat tool I found. For years, I have used cardboard behind the chain while lubing to limit spray to the chain.
Sadly, almost all chain lubes come in a spray can. Except 2 that I have yet to try. Sprays makes a mess. Cleaning and lubing a chain is the easy part, but cleaning up after sucks.
With the thing called a Grease Ninja (GN) you will never miss a link due to a shaky hand or distractions. Perfect lube job every time.
All you do is buy the right size GN for your chain size, and attach this thing to your can.
Trim your spray tube to length to minimize excessive bending of tube and attach to the plastic block.
Place on chain, spin wheel and spray at the same time.
Unfortunately the sprays come out very fast. To avoid over spraying I have to spin quickly. Sometimes the plastic block catches and slows me down a little. This is the only problem I had. If the edges that touch the chain were more rounded this would be less likely to happen.
Anyway, been using the GN for a few months and its a neat tool. No more cardboard for me. Check it out here:
http://greaseninja.com/
Less cleanup, more riding.
n0cars4me is offline   Reply With Quote
Old 08-16-2012, 08:31 AM   #2
Chain Smoker
Out On The Road Somewhere
Chain Smoker's Avatar
  West Coast USA
  Stage 4 Pirate Glide
Re: grease ninja review
I use a pickle. You should try one. Here is a link.
http://www.webbikeworld.com/t2/chain-pickle/
No clean up. More riding.
If you have Allis Chalmers air filter, Massey Ferguson oil filter, New Holland fuel filter, Case cams, John Deere shocks, Farmall heads and Screaming Beagle pipes you may be Stage Kit 1.75 or higher.
Chain Smoker is offline   Reply With Quote
Old 08-16-2012, 10:35 AM   #3
Moedad
Moedad's Avatar
  Orange County
  05 Wee Strom
Pickle for cleaning, Grease Ninja for lubing. Done.
Moedad is offline   Reply With Quote
Old 08-21-2012, 01:24 PM   #4
Chain Smoker
  West Coast USA
Olive oil. EVOO to be exact.
REVIEW: Swann Freestyle HD camera system deaconblues Mods, Gadgets & Gear 0 06-23-2012 05:49 PM
700 Miles on a Kawasaki Ninja 250 - A motorcyclist's review pashnit Motorcycle Photography 186 04-30-2012 08:08 AM
